Deletes a pre-defined action set.
| access-list | Specifies access-list features. |
| action-set | Specifies deleting an action set, which is a defined a set of actions that can be applied to multiple sets of match conditions. |
| set-id | Specifies which action set to delete by its global action set ID. |
N/A.
The following example deletes action set "1":
# delete policy access-list action-set 1
This command was first available in ExtremeXOS 30.5.
